2000 Chevy Prizm burning excessive oil
157,215 MILES • 4 CYL • FWD • AUTOMATIC
TIREDCAROWNER
Hi, for several months now, my car is burning/using up lot of engine oil. I tried adding some treatment from auto stores which claim to reduce consumption. Lately I am using over 75000 mile engine oil. If I use it long (4 or 5 times), would it help. Should I be wasting money by using this expensive oil? I dont see any benefit now. I had used two quarts already and also used RISLINE compression repair with ring seal. Has not seen any benefit so far.
Do you have any recommendations how to correct it. I need to add 1 quart every 100 mile to keep the level. It runs smoothly, so don't feel like replacing it.
Please help.
Feb 7, 2009 at 2:54 AM
MMPRINCE4000
  • 8,548 POSTS
Check for leaks first, front and rear main seals, valve cover gasket etc.
If you find a leak, fix it. If high oil consumption continues, perform a compression/leak down test, to see if it is an internal piston ring/valve seal/guide problem.
Feb 8, 2009 at 1:01 AM
