2000 Chevy Prizm 2000 prizm misfire
2000 CHEVROLET PRIZM
ERICW1
Engine Performance problem
2000 Chevy Prizm 4 cyl Front Wheel Drive Automatic
got a number 4 cyl misfire code,replaced plugs,swap coil with 3 and problem followed coil.replaced coil,problem still there,what look for next?it has very rough idle(if it idles)doggy,number 4 plug gas fouled.smokes when starts,any help be great
Dec 9, 2009 at 12:28 AM
MMPRINCE4000
  • 8,548 POSTS
Start by performing a compression test on all cylinders. Engines need spark, fuel and compression to fire. If compression is low, could be a stuck valve or possible headgasket.
Jan 17, 2010 at 12:03 AM
