2000 Chevy Prizm
KRISKRIS
Engine Cooling problem
2000 Chevy Prizm 4 cyl Two Wheel Drive Automatic
can you replace the thermostat without taking out the alternator?
May 12, 2009 at 10:47 AM
  • 110,246 POSTS
It is much easier to remove the alt to get to it. You will need to clean the surface of old gasket material, so remove it or you will drive yourself crazy trying to do it. Make sure to disconnect the battery before removing the alt.
Jul 24, 2009 at 4:29 PM
