1995 Chevy Prizm I cant find a way to scan my codes
17,200 MILES • 4 CYL • 2WD • AUTOMATIC
HUNTRESS
I have a1995 Geo prizim. The engin light is on and I can't seem to find a code reader. the only person that I found that says they can scan it wants $150 I can't afford that. In the morning the car will start then cut off and it will be several times untill it will stay running. It seems to be getting worse each day. Lately it has been cutting off when i'm at a red light or stuck in traffic. Do you have any ideas? Thank you
Sep 8, 2010 at 3:36 PM
DOCFIXIT
  • 18,828 POSTS
Find test terminal underhood by left shock tower jumper from TE1 to E1 paper clips works. turn key on MIL will flash so flash pause flash,flash = 12
then post codes will advise
Sep 9, 2010 at 4:07 AM
