won't start in morning
CHEVROLET
DONEGANS
2000-1500 silverado 4.3 litre. started having starting problems about a mon. ago w/ hard starting-seemed like fuel pblm. the thing is that once I got her going she ran fine all day and cranked fine--but overnight to next morning she'd get bad. Now she won't crank but spits like she wants to run--changed fuel filter and pump seems to run--checked computer code and it read fuel pressure hi or low plus some other readings that as far as i can tell are not fire/fuel related.talked to guys at parts place, they said fuel pressure regulator or air intake compensator? ANYONE had this problems? HELP--I'm dead in the driveway :?: :x
Jan 2, 2007 at 10:48 AM
MATHIASO
  • 1,209 POSTS
According to your input, have a mechanic change the unit ( regulator and fuel pump )
or have them do fuel pressure test first or you may ask them scan your pcm again and come back here with the codes, that could help.
Jan 2, 2007 at 12:52 PM
