wont start
CHEVROLET
JCAST27
2004 chev classic E C O tec 2.2 liter 70,000miles
engine cranks over ,has 56 lbs fuel pressure in gas rail. when i pour a little gas in throttle body engine starts for a couple of seconds then dies out? i
tried OBD 11 auto scanner , no codes found! now what? appreciate any ideas that can help.
Aug 25, 2007 at 12:26 PM
  • 75,988 POSTS
[quote:7f595205e7="jcast27"]2004 chev classic E C O tec 2.2 liter 70,000miles
engine cranks over ,has 56 lbs fuel pressure in gas rail. when i poor a little gas in throttle body engine starts for a couple of seconds then dies out?
tried OBD 11 auto scanner no codes found! now what?
already made a donation thanks[/quote:7f595205e7]
Sounds like the injectors are not pulsing or its clogged up-could also be the driver in the computer or the computer is not getting a reference signal from the ignition and preventing the injector to come On to prevent the catalytic converter from burning up. Also could be inadequate fuel pressure.
Good Luck
Aug 25, 2007 at 12:33 PM
