1994 Chevrolet Camaro No Crank
CHEVROLET
HABUCCIL
I have a 1994 Z28 camaro with 5.7 motor that has 139,000 miles. It won't start! When I turn the key nothing happens. I have replaced the battery and had the starter tested and it is fine. What next? :(
Jan 12, 2007 at 4:41 AM
SERVICE WRITER
  • 9,123 POSTS
Thorougly check the cables that run from the battery to ground and to the starter for any looseness or corrosion.
Was the battery replaced in an attempt to fix the no crank?
Jan 12, 2007 at 9:09 AM
Suggested Repair
Thoroughly inspect the battery cables to ground and to the starter for looseness or corrosion.
Conversation Summary
A 1994 Chevrolet Camaro Z28 with a 5.7 engine and 139,000 miles will not crank when the key is turned. The battery was replaced and the starter tested fine. The expert advises checking the battery-to-ground and battery-to-starter cables for looseness or corrosion, and asks whether the battery was replaced specifically to fix the no-crank condition.
