truck won't start
CHEVROLET
PHIL_WR
  • 9 POSTS
I have a 1991 chevy S-10 4 cylinder 5 speed manual I dont know about the miles the mileage is stuck on 156,000. I pulled up in front of the store and shut my truck off, and I went inside. When I came back out it would'nt start. I checked to see if it was getting fuel and it was'nt? So I checked to see if the fuel pump was coming on when I turned the key on and it was. So I checked to see if it was getting a spark and it was not? oh and I checked the fuses and they are all good. What could it be?
Jan 11, 2007 at 2:20 PM
SERVICE WRITER
  • 9,123 POSTS
Were the conditions damp?
How had it been running?
Any recent repairs?
Jan 12, 2007 at 2:06 AM
PHIL_WR
  • 9 POSTS
it was dry outside. i had no problems before. and no recent repairs.
Jan 12, 2007 at 2:13 AM
SERVICE WRITER
  • 9,123 POSTS
When was the last time the cap, rotor and wires, Plugs were changed. Not saying this is the problem but still important and potentially relevant.
Check your e-mail.
Jan 12, 2007 at 2:17 AM
PHIL_WR
  • 9 POSTS
I dont really know I bought the truck 4 months ago and i haven't changed them so?
Jan 12, 2007 at 2:23 AM
SERVICE WRITER
  • 9,123 POSTS
I misunderstood, :oops:
no spark, no fuel, but pump runs.
Jan 12, 2007 at 4:18 AM
PHIL_WR
  • 9 POSTS
yes.
Jan 12, 2007 at 5:00 AM
SERVICE WRITER
  • 9,123 POSTS
Do you want to use the 2nd troubleshooting sheet I sent?
Jan 12, 2007 at 5:04 AM
PHIL_WR
  • 9 POSTS
tried that still cant figure it out.
Jan 12, 2007 at 5:14 AM
SERVICE WRITER
  • 9,123 POSTS
Maybe someone else can pick up on this and help you out. Short of that I can guess if you want.
Jan 12, 2007 at 5:21 AM
PHIL_WR
  • 9 POSTS
Thanks for all your help I cant figure it out either.
Jan 12, 2007 at 5:37 AM
QUALITYMIKE
  • 7 POSTS
You asked me for my opinion so, here it goes.
You said "no spark", so I would start there. Before changing things I would check all electical connections to make sure that something has not come loose or a connector has not burned through, I had this happen once. I would also check the fuses again and test them by replacing each one with a new one. Sometimes it is difficult to 'see' if a fuse is burnt out. No spark at all could be the coil, but I would change out the cap, rotor, plugs and new wires. It probably needs it anyway. If still no-go, then I would change the coil.
Hope that helps.
Jan 12, 2007 at 9:50 AM
