right vent makes knocking noise when car is turned on or off
CHEVROLET
MCOWLEY
I have a 1994 Chevy Suburban with 183000 miles. The front passenger vent makes a knocking noise for about 20 seconds every time I turn on or turn off the car. Or more accurately, the problem noise happens every time I turn the key to the on or off position (the car does not need to be running). I believe the problem is with the vent door opening and closing repeatedly (about 5 knocks per second). The same noise occurs when I press the "max" button which turns on air recirculation and when I turn it off.
What is causing this problem? How do I locate and replace the malfunctioning part?
Thanks in advance!
Nov 23, 2006 at 5:07 AM
GMX
  • 37 POSTS
UR MODE SELECTOR DOOR MOTOR ( GOOD LUCK )
Nov 24, 2006 at 3:23 PM
JLEDDINS
I have exactly the same problem with my 1994 Cheyenne,4.3 engine, and 205,000 miles. Sure wish sombody could help, I can pull the AC fuse and the knocking quits but then I don't have a vent, AC, or defroster.
Thanks for your help in advance,
Jerry
Jul 31, 2007 at 11:58 AM
