Replace Temp Sensor. Problem not fixed
CHEVROLET
AIRBORN1357
  • 5 POSTS
01 chevy impala ls
Okay...car's running...temp gauge not working...I shut the car off...fan's still run. A few day's later...check engine light come's on. I get the code read...it says it's either the temp sensor or the thermostat. Today...I replace the thermostat...problem continues...so i went ahead and replace the temp sensor...and....problem still continues...lost here...has to be electical....burned or shorted wires or something...not sure...anyone have any ideas?
Dec 15, 2006 at 2:49 PM
KENVCR
  • 105 POSTS
Don't get to frustrated. The car now has a fault code stored after you replaced to parts.
After replacing the parts, did you unhook your battery for at least 5 minutes to clear any stored fault codes.
Try that first. On restart does the check engine light come on?
Are there any other visible signs that your car has a problem. Can you drive up on ramps, crawl under and look up at the bottom of the water pump. What you are checking for is a drip or drop of antifreeze coming from the bottom of the pump (weep hole). Since your temp sensor sent a fault code, this is another related part to check. A malfunctioning water pump should trigger your temp sensor. If you see so much as a drip in that weep hole, the indication is that the propeller shaft is worn and your pump is now defective.
Good luck,
Let us know the results please.
Kenvcr
Dec 15, 2006 at 6:15 PM
AIRBORN1357
  • 5 POSTS
well....i when i did this...coolant came out and kind of went everywhere....i got to wait till it burns up and stuff to see if there is anything leaking...but will do so....thanks alot.
Dec 16, 2006 at 12:23 AM
