2000 Chevy S10 Bent Frame and Airbag Light
CHEVROLET
DRSLASH2001
I was recently rear ended. My 2000 chevy s10 frame was bent silghtly behind the driver's side back wheel. If this is not repaired, what is the worst I can expect. Also, I was knocked into the car in front of me. I barely tapped the car, but my air bag light is on. What needs to be done?
Jan 12, 2007 at 11:44 PM
SERVICE WRITER
  • 9,123 POSTS
Probably severe tire wear to a loss of control if something was broken. Should get it looked at and the alignment specs read.
Aig bad light may be relate to one of the crash sensors in the front of the truck.
Ned to find what codes are in the computer for that.
Jan 13, 2007 at 12:34 AM
Suggested Repair
Have the bent frame inspected and the alignment specifications checked, since unrepaired damage can cause severe tire wear or loss of control if something is broken. Scan the airbag system for codes, as the warning light may be related to a front crash sensor.
Conversation Summary
The owner of a 2000 Chevrolet S10 was rear-ended, slightly bending the frame behind the driver's-side rear wheel, and then lightly struck the vehicle ahead, after which the airbag light came on. The expert warned that unrepaired damage could lead to severe tire wear or loss of control if something is broken, and recommended an inspection and alignment check. The airbag light may be tied to a front crash sensor, so the related computer codes should be retrieved.
