Power goes to distributor but doesn't come out
CHEVROLET
M-A-R-I-Y-A-H
Chevy Suburban 1996 1500 4x4 140,000 I went outside to start my truck the other day and after many tries i found that it wan't going to happen. When I started checking it out I found that there was power going all the way to the distributor so i replaced the rotor and the cap but after that it is still not comming out to reach the wires. Any advise on what I should change next???
Jun 9, 2006 at 2:04 PM
SYNCRAIT
  • 235 POSTS
check the resistance in the plug wires with a multimeter
Jun 9, 2006 at 11:41 PM
VANMAN42
  • 23 POSTS
check the module , some parts stores can test it to see if it's bad.
Jun 10, 2006 at 1:58 PM
SYNCRAIT
  • 235 POSTS
if you can get someone to turn it over when the sun has already gone down and look for arcing around the ignition coil wire or the plug wires
Jun 11, 2006 at 1:42 PM
