I have fresh air entering through the air cleaner and fresh air pipe on the pass.side and PCV on the driver side. I also have an oil filler hole on the driver side. Could I add a second PCV on the driver side in the oil fill hole, connect in with the existing PCV. With the vacuum being unchanged this would reduce the amount of air being discharged by the single PCV. This would split the air flow and reduce the amount of oil that is carried by the air flow.
JohnA
