2003 Chevrolet Silverado Decel Noise
CHEVROLET
HANES289
I have a 2003 Silverado 4x4, 49,000 miles, just had the front differential rebuilt by gm because of noise when accelerating, now I got it back, and works great accelerating, but when i let off the gas, it makes noises, still coming from the front end, could it be something other than the differential?
Jan 2, 2007 at 4:45 PM
2CARPRO JACK
  • 11,533 POSTS
You sure its the front end and not the transfer case?If your positive then you might want to take it back.It sounds like they might have missed the set-up on the front gear set.Before you take it back check the front wheel bearings, they have a tendancy to go out, non serviceable bearing.
Jan 2, 2007 at 11:21 PM
Suggested Repair
Confirm the noise is from the front end rather than the transfer case. Check the non-serviceable front wheel bearings, which commonly fail. If the noise is confirmed at the front differential, return it to the shop because the front gear set may not have been set up correctly.
Conversation Summary
A 2003 Chevrolet Silverado 4x4 with 49,000 miles had the front differential rebuilt for noise while accelerating. Acceleration is now quiet, but a front-end noise remains when decelerating. The expert suggested confirming it is not the transfer case, checking the front wheel bearings, and returning the truck if the front gear set setup was missed.
