1996 Chevrolet Suburban Fuel Pump No Power Fix
CHEVROLET
BOB WILSON
  • 13 POSTS
I HAVE A 96' SUBURBAN 5.7 143000MI
THE FUEL PUMP QUIT SO I REPLACED IT. THE NEW RAN FOR FIVE MINUTES AND QUIT. UPON REMOVING THE NEW, I RAN HOT AND GROUND DIRECT TO PUMP OUT OF TANK AND THE PUMP WORKED. ALSO THE PREVIOUS PUMP WORKED THIS WAY. MY CENTER PRONG WIRE AT THE PUMP READS 8.4V AND NO VOLTAGE AT THE GRAY. MY HAYNES MANUAL DIAGRAM SHOWS ORANGE FROM THE RELAY TO AN OIL PRESSURE SWITCH, THEN GRAY TO PUMP. I CAN'T FIND SWITCH TO FIND THE GRAY WIRE AND THE VOLTAGE LOSS.
OR COULD IT BE SOMETHING ELSE. FUSE IS GOOD AND NEW RELAY INSTALLED. MY CODE READER SHOWS MAV CIRCUIT LOW?
Dec 30, 2006 at 10:14 AM
SERVICE WRITER
  • 9,123 POSTS
I'm not sure what years, but some of the GM trucks in that period had a bad connector that went to the pump. The stealer may be able to provide you with that info, where you would have to buy it anyways.
Good luck.
Dec 30, 2006 at 3:00 PM
2CARPRO JACK
  • 11,533 POSTS
Definitly go to the dealer and get the revised connector for the pump.They had big problems with them. Also replace the fuel pump relay any time you do a pump, its cheap insurance that the circuit is ok.The code MAV? was it MAF?. 96 should be a CPI engine.Most likely needs a new MAF sensor.Seeing more and more of them failing these days.
Dec 31, 2006 at 12:04 AM
BOB WILSON
  • 13 POSTS
THANKS FOR THE HELP,
WHICH CONNECTOR? IS IT THE ONE TO THE FUEL PUMP IN FRONT OF TANK, OR THE ONE TO PUMP INSIDE OF TANK. MY MANUAL SHOWS A MASS AIR VOLUME SENSOR, NOT A MAF. PLEASE DON'T SAY THE ONE IN THE TANK, I'VE DROPPED AND INSTALLED IT TWICE ALREADY WITH 3/4 TANK OF GAS. DO YOU KNOW WHERE TO FIND THE OIL PRESSURE/FUEL PUMP SWITH? LAST QUESTION, WOULD THE MAV SENSOR, WHICH IS GETTING 12V, ACTUALLY STOP THE FUEL DELIVERY?
THANKS AGAIN
Dec 31, 2006 at 1:13 PM
2CARPRO JACK
  • 11,533 POSTS
All the connectors.Yes the MAF will adjust mixture as it sees fit, if its out of range then the mixture isnt correct
Jan 3, 2007 at 9:02 AM
Suggested Repair
Get the revised fuel pump connector from the dealer, a known problem on these GM trucks, and check all pump connectors for voltage loss. The relay was already replaced. Also diagnose the MAF/MAV circuit-low code, as a failing MAF can throw the mixture out of range.
Conversation Summary
A 1996 Chevrolet Suburban 5.7 lost fuel-pump power after a new pump ran briefly. Direct power and ground made both pumps run, but the harness showed low voltage on one wire and none on the gray wire. The fuse and a new relay were good, and a MAV circuit-low code was present. Experts recommended the dealer revised pump connector and checking all connectors, and said a failing MAF can cause an incorrect mixture.
