No Front Parking Lights Or Drl's
CHEVROLET
Q8_Z71
Chevy Silverado 2001-[u:8271d62ccd] No Front Parking Lights Or Drl's[/u:8271d62ccd]
Any ideas why this would be or what to check, pretty sure I found and checked any fuse that could cause it.
Blinkers work, just no parking lamps or drl's.
Thanks in advance.
Jul 15, 2006 at 8:55 AM
MIKEYBDMAN
  • 623 POSTS
[quote:510e0d4e72="q8_z71"]Chevy Silverado 2001-[u:510e0d4e72] No Front Parking Lights Or Drl's[/u:510e0d4e72]
Thanks in advance.[/quote:510e0d4e72]
Ok, I see two things that tie in to each system. First is the G100 ground. There should be a small wire that comes out of the forward lamp harness on the left front body mount. This wire grounds to the same stud as the negative battery cable. I would check that ground and wire for loosness, corrosion and breaks.
The other is the Body Control Module. But that seems rather odd that it would effect both items.
Jul 15, 2006 at 9:41 AM
Q8_Z71
Thanks bud.. will check n let ya know!
:D
Jul 15, 2006 at 9:58 AM
