need help locating electrical short
CHEVROLET
GSBELIEVER
Have a 98 Blazer, 4 door, 109k miles. The left rear turn signal and brake light stopped working (taillight works fine). Replaced bulbs, flasher and fuse, but fuse keeps blowing. Unplugged harness to left rear lights and fuse still blows. Can you suggest a starting place to look for apparent short??
Dec 29, 2006 at 2:58 AM
KENVCR
  • 105 POSTS
The actual bulb socket itself. Parts stores carry these. They get moisture in them, they rust, they cause the short. If the bottom of your bulb socket looks a little rusty, splice it out with a new one. Otherwise looking for a short along the line can take a while to find.
Let us know what happens.
Kenvcr
Dec 31, 2006 at 4:57 AM
TKMNBJM
  • 9 POSTS
Try replacing your turn signal switch inside the steering column..good luck.
Dec 31, 2006 at 2:03 PM
