2000 Chevy Venture Overheating
CHEVROLET
My van has multiple problems. It is a 2000 Chevy Venture, 130910-mileage. First there is a noise, that sounds like the power steering pump. On further inspection someone told us that it was the alternator pulley. Recently it started overheating, and the low coolant light came on. We filled it with coolant, and still overheating. Then the water pump went out, replaced it right away. Now we have water in the oil. When driving a short distance it starts wanting to stop, and when it does, it doesn't start. I have to wait for awhile, then it starts back up. I haven't had it checked by a mechanic yet. I was wondering what it could be? I don't know anything about cars. I will be taking it to a mechanic shop soon. Just wanted to know ahead of time what the could be wrong with my van.
Dec 26, 2006 at 1:07 PM
Becareful, these are common for intake manifold gasket leaks that can end the useable life of the motor if it doesn't get prompt attention.
I don't know that this is the case, but it isn't worth the risk...is it?
Dec 26, 2006 at 1:12 PM
Suggested Repair
Have the intake manifold gasket inspected promptly. Coolant loss, overheating, and water in the oil are consistent with a leaking intake gasket, which can ruin the engine if ignored. Also have the stalling, hard restart, and earlier pulley noise checked.
Conversation Summary
The owner of a 2000 Chevy Venture with about 131,000 miles reported a noise thought to be the power steering pump or alternator pulley, then overheating and a low-coolant light that continued after adding coolant. After the water pump was replaced, coolant appeared in the oil, and the van began dying after short drives and would not restart until it sat. The expert warned that these vans commonly develop intake manifold gasket leaks that can destroy the engine without prompt attention.
