Is this my fuel injection?
CHEVROLET
BMARSHALL
2003 chevy 4.3 v6
I was driving down the road and i thought i had ran over something in the road, it made a little thud noise. Then a little while later i noticed my truck wasnt running right. about 10 miles down the road my engine light came on. I took it to the chevy dealer and the code they got was an 0300 which is a misfire. they tested my compression and it was ok and they said they tested my injectors and they didn't balance. I took it home and put a new fuel filter on hoping for the best but it seems to be worse. it still idles bad and makes the thys noise when im up around 30mph. i dont want to have to replace the fuel injection. also my buddy was driving behind me and said he could smell gas real bad. waht do you think. thanks
Sep 21, 2006 at 10:32 AM
DIGUGLIELMO
  • 28 POSTS
sounds like your running a little rich, check the timing, pull the injector cap off of each injector (there should only be two) and put them under a tester, u can rent that at your local auto parts store. also see if one of your fuel lines is broken
Sep 25, 2006 at 6:49 PM
