1996 Chevy Blazer Hood Squeak
CHEVROLET
NYARBER
Hello all and this is my very first car a 96 Chevy Blazer with like 116xxxx miles and I have run into a problem, there is some type of squeaking noise coming from under the hood. Now my mechanic told me it was the idler pulley and I got that changed and that was not it either, then he said some kind of suspesion part or something and I got that changed too but it still makes the squeaking sound whenever I press on the gas and it will also make it when I am at a stop but it is not so loud. Some other guy metioned something about maybe it could be the water pump please tell me what you think because I want the squeaking to stop. I should also mention before this noise started I also had to have the alternator replaced.
Aug 11, 2006 at 1:36 AM
2CARPRO JACK
  • 11,533 POSTS
i would inspect the belt and the belt tensioner.If the alt was replaced with a unit with a smaller pulley, then the belt might be a little too long.Remove the belt and spin the accessories to see if you can replicate the noise
Nov 30, 2006 at 9:27 AM
Suggested Repair
Inspect the drive belt and belt tensioner. If the replacement alternator has a smaller pulley, the belt may be too long. Remove the belt and spin the accessories by hand to see which one makes the squeak.
Conversation Summary
The owner of a 1996 Chevy Blazer reports a squeak under the hood that is louder when accelerating and quieter at a stop. The idler pulley and a suspension part were replaced without fixing it, and the alternator was replaced before the noise began. The expert advises inspecting the belt and tensioner, noting a smaller alternator pulley could leave the belt too long, and spinning the accessories with the belt removed to isolate the noise.
