Chevrolet 350 Dies After Cranking
Thomas
Suggested Repair
Do not hold the key in start, which keeps the starter engaged. Check the ignition switch and the ballast resistor that feeds the coil in the run position. A failed resistor or missing/miswired resistor can drop coil voltage after cranking. As a test, briefly supply 12 volts to the coil positive and try starting without holding the key in start; if it then runs until that feed is removed, the run-circuit feed is the fault. Typical ballast resistance is about 8 ohms, but it varies by coil.
Conversation Summary
A boat with a Chevrolet 350 starts while the key is held in start, then dies as soon as the key is released. Coil voltage is present only during cranking and disappears in the run position. One reply suspects a defective ignition switch and warns against holding the starter engaged; a second reply also points to an open, missing, or miswired ballast resistor that should feed reduced voltage to the coil in run. Both recommend checking the switch and resistor.
