1997 1500 5.0 (M) 2wd.I've already replaced fuel pump, cap, rotor, plugs, wires, module, csfi module, fuel filter, pick up coil, coil, starter. I first tried to start her with injection cleaner, it worked. now I cant get her to stay running. Spark is good, fuel pressure is good. fuel pressure stays at 59 for 10 mins before it starts to drop. I have restabbed the distributor 3 times now and no results.I work at a shop and none of the techs can figure it out. Weve got atleast 75 years worth of experience between us all. I'm am broke and exhausted.I dont know what else could cause it not to start. I pulled the plugs for the 3rd time and #3 n #5 were the only ones that were dirty,bent valves??? I'd appreciate any help you can give me. Thanks. :?:
Jan 13, 2007 at 2:36 PM
