2003 Chevy S10 Heater Stuck on Dash Vents Fix
CHEVROLET
UNSAVVY
2003 Chevy S10 pickup, 53,500 miles, 4.3 engine
When the heater is turned on in this truck, all the heat comes through the dash vents. The options are defrost, dash vents, or floor, but I am unable to switch to the different places. I like the airconditioning to come through the dash vents, but not the heat. Anyone know what has caused this, or how to fix it. It used to work properly. It seems to be stuck on the dash vents.
Jan 20, 2007 at 6:23 AM
BOOTDOG
  • 665 POSTS
you probably have an electric heater/ac control switch. if so, the actuator that moves the blender door from floor to vent to defrost is bad. it's located on the heater box which i beileve on your truck is behind the dash. you may need to get a repair manual to find the easiest access on replacing that actuator. good luck on your repairs.
Jan 20, 2007 at 7:21 AM
Suggested Repair
The mode door actuator that directs air between the floor, dash vents, and defrost is likely failed. It is on the heater box behind the dash; use a repair manual to find the easiest access and replace the actuator.
Conversation Summary
A 2003 Chevy S10 with a 4.3 engine sends all heat through the dash vents and will not switch to floor or defrost, although it used to work. The expert said the electric mode door actuator on the heater box behind the dash is probably bad and should be replaced, using a repair manual for access.
