1955 Chevrolet Bel Air Headlight Switch
You also need to take a look inside the radiator and make sure that the tubes or not clogged, preventing sufficient water flow to cool the engine.
This site has diagrams for 1940's on up I believe. Good luck and hope this helps. :D
Suggested Repair
Use a 1955 Chevrolet wiring diagram to trace each wire. The first switch position should feed the parking/tail lights and dash lights, while the full-on position adds the headlight feed to the floor dimmer switch. Match wires by color and destination, and remove the switch or dash panel if needed for access.
Conversation Summary
The owner of a 1955 Chevrolet Bel Air disconnected seven individual wires from an unmarked original-style headlight switch and could not identify the terminals. Unrelated replies discussed radiator problems. Experts recommended a period Chevy wiring diagram and explained that the first position powers parking/tail and dash lights, while full-on adds the headlight circuit through the floor dimmer switch, allowing the wires to be matched by color and destination.
