fuel pump relay
CHEVROLET
HWPJ
  • 5 POSTS
I have a fuel pump problem and i want to check the relay could you tell me where it is located. it is on a 1993 cavalier
thank you
Harold
Jan 21, 2007 at 10:36 PM
CARUNDELL
  • 602 POSTS
[quote:64ee5deb20="hwpj"]I have a fuel pump problem and i want to check the relay could you tell me where it is located. it is on a 1993 cavalier
thank you
Harold[/quote:64ee5deb20]
Hey hw,
The fuel pump relay should be located under in the engine compartment, mounted behind the right (pass.) headlight assy. Let me know!!
Chris
Jan 22, 2007 at 3:35 AM
HWPJ
  • 5 POSTS
i didn't see any relay behind the headlite assemby only saw three on right side up by the fire wall.thanks for replying so fast.
if you have any other ideas please let me know
thanks
Harold
Jan 22, 2007 at 6:41 AM
CARUNDELL
  • 602 POSTS
Hey Harold,
Sorry! My bad, its located behind the right (pass.) strut tower. You should be able to identify it a lg. red and pink/blue wires going into it.
Chris
p.s. will send along the diagram if ya need it!
Jan 22, 2007 at 7:53 AM
HWPJ
  • 5 POSTS
sorry if i sound dumb but is there more than just the red pink/blue wire going in to it? if you could send the diagram it sure would help.thank you for all your help
Harold
Jan 22, 2007 at 9:08 AM
CARUNDELL
  • 602 POSTS
Should be in your email!
Chris
Jan 22, 2007 at 9:29 AM
HWPJ
  • 5 POSTS
i got it thanks for all the help i will let you know how i make out with it
Harold
Jan 22, 2007 at 9:58 AM
HWPJ
  • 5 POSTS
ok i got the relay but that didn't fix it.let me ask you a question if i disconnect the fuel filter and turn the ignition on like i am trying to start the car,shouldn't gas pump out the line? please let me know
Thanks
Harold
Jan 23, 2007 at 10:23 AM
