1990 Chevy Lumina APV No Start
-Binding or sticking TPS, or high TPS voltage with throttle closed.
-High resistance in coolant sensor circuit (see Trouble Code 15).
-Incorrect fuel pressure or contaminated fuel.
-Improper EGR operation, leaking, binding or sticking EGR valve.
-Ignition system malfunction, worn damaged or fouled spark plugs.
-Defective in-tank fuel pump check valve allowing fuel to drain back to tank after engine is stopped.
-On V6-173 (2.8L) if engine starts, then dies, open distributor bypass line. If engine starts and runs properly, replace pickup coil.
Suggested Repair
Suspect a defective in-tank fuel pump check valve that lets fuel drain back after shutdown. Also check fuel pressure and contamination, closed-throttle TPS voltage, EGR operation, spark plugs and ignition, and coolant-sensor circuit resistance, which can affect timing and starting but not fuel delivery.
Conversation Summary
A 1990 Chevrolet Lumina APV will not start after sitting about two hours, but starts and keeps running if a little gasoline is poured into the throttle body. Replacing the regulator diaphragm did not help. The expert said the in-tank fuel pump check valve is a likely cause of fuel drain-back and listed checks for fuel pressure, TPS, EGR, ignition, and the coolant sensor. The coolant sensor does not control fuel delivery but can affect timing; a cooling-fan complaint was mentioned but not diagnosed.
