2002 Chevy Trailblazer Front Wipers Out
CHEVROLET
THECHALLENG2
2002 Chevy Trailblazer LT Vortec V6 4.2_mileage: 60,000. OK here is my problem. I have 2 subs and a amp in my truck the amp went out and some of the plugs came out. I pluged them back in and the amp worked. I then drove home and the amp went out again. when i was at my house i went to use my wipers and they did not work. my rear wiper works fine just not my front wiper. This is a inconvience seeing as we have had bad weather and i need to see out of my window. I would enjoy fixing this so that i dont have to do drive to work in reverse any longer. One of these days i will get puled over and have to explain why i am driving everywhere backwards. What could be the problem so that i can stip living life in reverse please help me thanks.
Mar 1, 2007 at 6:24 PM
CHEVY22
  • 1,375 POSTS
have you checked the fuses ??? check all of them , it sounds like you had a short to ground when the amp wires came out , but if the fuses check out it may not be related ,
get back to us
jim
Mar 1, 2007 at 9:41 PM
Suggested Repair
Check all fuses. A short to ground may have occurred when the amplifier wires came loose. If the fuses are good, the wiper problem may be unrelated.
Conversation Summary
The owner of a 2002 Chevy Trailblazer says the front wipers stopped working after amplifier wiring plugs came loose and were reconnected. The rear wiper still works. The expert advises checking all fuses because a short to ground may have occurred, and notes the issues may be unrelated if the fuses are intact.
