1997 Chevy Blazer 4WD Won't Engage
I replaced my accuator, but it always stays depressed unless I disconnect the vacuum line. And it doesn't go all the way into the 4x4 just makes a mild clanking like its just barely in 4x4
I don't know what controls the vacuum. I tried pulling on the cable and I can't pull it far enough to engage the 4x4 either?
any advice?
TIA
[update] I had to replace the vacuum switch on the transfer case, now the acuator works fine.
any advice?
TIA[/quote:ece86527b0]
[update]
I have a 1996 Blazer 4x4 with manual shift 4x4 (not dash button) my differential is not engaging as it should.
The vacuum acuator was bad, replaced. The vacuum switch was bad, replaced. The cable may have been bad, replaced.
I took the cable off at the housing on the differential and removed the housing face plate. I used a pair of vise grips to pull the acuator out to engage the 4x4 but all it would do is grind mildly, all it would do is grind mildly when I had it all
connected too.
So I have traced the problem to the differential. I cant seem to engage the "collar" for the axles to engage.
I just don't know what to do from there? any ideas would be appreciated.
TIA it's appreciated.
Suggested Repair
Replace the sticky front axle vacuum actuator with the updated heated unit. For lights and gauges that pulsate with RPM, check grounds and power connections and test the alternator and voltage regulator.
Conversation Summary
A 1997 Chevrolet Blazer owner said the front wheels would not engage in 4-high or 4-low, although the front driveshaft engaged and the vacuum actuator moved stickily. The front differential had been low on fluid and was refilled. Experts identified the actuator as the common four-wheel-drive fault and advised checking grounds, power connections, the voltage regulator, and alternator for the pulsating lights. Later posts about a similar 1996 Blazer said the actuator, transfer-case vacuum switch, and cable were replaced, with grinding still traced to the differential collar, but no further expert repair was given.
