Flood water shut my car off
CHEVROLET
JLJOHN3
I have a 1987 chevy corsica. It has 86000 miles and I jus recenlty got stuck in some high fllood water. When I first got the car towed back home it did not do anything. Then I sprayed some WD-40 randomly around the inside of the hoods car parts. Now it revs foever but nothing happens. What's wrong? What should I do?
Sep 6, 2006 at 3:29 PM
DARKMUSHROOM901
  • 12 POSTS
ok water in the eng isnt good... at all.. i would take off your sparkpulg caps, and check for water, ill bet ya money that theres alot lol. get a ratchet and a long sized end that fits the spark plug (sry im not sure on the size) and undo them and take them out the water will go into a place were it will burn off and not mess up your car. take the spark plugs and dry them off, then pul them back in. make sure the water drained down.. and no you dont have to dry the inside out. pul them back in and the caps back on and give it a crank. a wise thing to do is only do one spark plug at a time so that you don't get the plugs mixed up (thats very bad idea) its not hard to do even if ur not good or new with engins, just take your time and watch what your doing. also i for got to tell you to dry off the spark plug caps shake them out goood and dry.. hope that will fix your problum. if not try a tuneup, go to autozone and ask them to help u out with a tuneup thay will help you out.
Sep 7, 2006 at 1:45 PM
DARKMUSHROOM901
  • 12 POSTS
p.s wd 40 works wonders but it can b very bad in some spots of the eng... so dont spray it if ya dont know what it dose lol
Sep 7, 2006 at 1:47 PM
MILL65
I have a 2001 toyota celica gt now it wont start and has water in the engine and air filter i didnt get it hot i only was on my way out of my parking lot at work it stalled and i pushed it back in a paking place called a wrecker the next day went to open my breather and it was full checked the oil and it looks like it has water too . did i crack the block or head what sould i do next?
Aug 19, 2007 at 11:52 AM
