1991 Chevy Lumina Firing Order
Hope that helps
Suggested Repair
Turn the crankshaft clockwise until the timing marks align at zero, then confirm cylinder 1 is on the compression stroke by feeling compression at the #1 plug or checking that both #1 valves are closed. With #1 at TDC, install the #1 plug wire where the rotor points and route the remaining wires clockwise in the engine's firing order. In the future, remove only one plug wire at a time so the order is not lost.
Conversation Summary
The owner of a 1991 Chevy Lumina van with a 3.1L engine mixed up the plug wires and knows the firing order but not which distributor-cap terminal is #1. Replies explain how to set the crank to TDC, verify #1 compression, place the #1 wire at the rotor, and continue clockwise through the firing order. A V8 order was given only as an example; the 3.1 is noted as a V6.
