1995 Chevy Suburban Light Throttle Miss
CHEVROLET
CALEBZX9R
I have a 1995 suburban k2500 5.7l with 125000 miles
when it is cold it starts hard and misses for about a minute then idles fine. while driving, when i get up to speed and am giving it light throttle is misses pretty bad. if i let off the throttle, or give it more throttle is goes away. there doesnt appear to be loss of power at full throttle. i replaced the fuel pump about 1500 miles ago and i just replaced the fuel filter again. please help
Jan 21, 2007 at 4:34 PM
CARUNDELL
  • 602 POSTS
[quote:6c6aa2812e="calebzx9r"]I have a 1995 suburban k2500 5.7l with 125000 miles
when it is cold it starts hard and misses for about a minute then idles fine. while driving, when i get up to speed and am giving it light throttle is misses pretty bad. if i let off the throttle, or give it more throttle is goes away. there doesnt appear to be loss of power at full throttle. i replaced the fuel pump about 1500 miles ago and i just replaced the fuel filter again. please help[/quote:6c6aa2812e]
Hey caleb,
Sounds like you may have a bad plug wire or plug. When was the last tune up? Let me know!
Chris
Jan 22, 2007 at 3:48 AM
CALEBZX9R
I changed the plugs, wires, cap and rotor about 2000 miles ago. I also changed the MAP sensor.
thanks for the quick reply
Jan 22, 2007 at 4:28 AM
CARUNDELL
  • 602 POSTS
[quote:18383f0a82="calebzx9r"]I changed the plugs, wires, cap and rotor about 2000 miles ago. I also changed the MAP sensor.
thanks for the quick reply[/quote:18383f0a82]
Hey,
I would carefully inspect those ign wires for chafing or failure, especially @ the plugs .... you can also get a spray bottle w/ water and kind of hose down the cap and all the wires, look for arcing or a stumble in the engine. Was the map sensor changed because the old one failed or did you do that as a maint. item? Also check all the vacuum hoses and lines for cracks or breaks, a vacuum leak will also cause a skip (lean misfire) Another possibility the O2 sensor has failed or close to failure. But you would need a scanner do diagnose that one properly! Let me know!
Chris
Jan 22, 2007 at 4:39 AM
Suggested Repair
Inspect the ignition wires for chafing or failure, especially at the plugs, and spray water on the cap and wires while running to look for arcing or a stumble. Check vacuum hoses and lines for cracks that could cause a lean misfire, and scan for a failing oxygen sensor.
Conversation Summary
A 1995 Chevrolet Suburban K2500 5.7L with 125,000 miles starts hard and misses briefly when cold, then idles fine. At speed it misses under light throttle but clears when the throttle is released or opened further, with no full-throttle power loss. The fuel pump, fuel filter, plugs, wires, cap, rotor, and MAP sensor were recently replaced. The expert advised inspecting the ignition wires and cap for arcing, checking vacuum lines for leaks, and scanning for a failing oxygen sensor.
