2002 Chevy Trailblazer Engine Knock
CHEVROLET
TRAILBLAZERLT
2002 Chevy Trailblazer Lt with 167,000+ miles. The problem of engine knocking has since come about after I drive 30 miles or more at 65-70 miles per hour.
When decelerating and coming to a complete stop
the engine knocks like it has no oil. Once engaged back into normal in town stop and go driving, the knoocking disappears and the engine runs as it should.
The engines oil pressure gauge registers normal. No evidence of engine sludge, No loss of engine power.
I have noticed a moderate to severe vibration coming from the car while idling in drive but I don't know if this is in any way related to the knocking issue.
Dec 18, 2006 at 2:18 AM
BOOTDOG
  • 665 POSTS
i would look into the water pump on the knocking issue. i've seen it more than once on GM vehicles, including my own. remove the drive belt and see if it goes away. i wouldn't relate the vibration to the knock. good luck
Dec 19, 2006 at 12:04 AM
Suggested Repair
Inspect the water pump. Remove the drive belt and see if the knocking stops. The idle vibration is likely unrelated.
Conversation Summary
A 2002 Chevy Trailblazer with over 167,000 miles knocks after 30 or more miles at highway speed, especially when decelerating to a stop, then runs normally in stop-and-go driving. Oil pressure is normal, with no sludge or power loss. An expert suggests checking the water pump and removing the drive belt to see if the knock goes away, and does not relate the idle vibration to the knock.
