1992 Chevy Lumina APV No Gauges
CHEVROLET
VIZAR1964
I have a 92 Chevy Lumina APV that the AC clutch froze up on. now i have no speedometer, oil pressure gauge, rear window wiper or heat. I know there is some wiring damage from this. Where can i find a wiring diagram for this vehicle.
thanks for all your help
Jan 1, 2007 at 8:04 AM
MIKEYBDMAN
  • 623 POSTS
[quote:283e04a25c="vizar1964"]I have a 92 Chevy Lumina APV that the AC clutch froze up on. now i have no speedometer, oil pressure gauge, rear window wiper or heat. I know there is some wiring damage from this. Where can i find a wiring diagram for this vehicle.
thanks for all your help[/quote:283e04a25c]
Im trying to find a common connection between your systems, but Im not finding all of them. The oil pressure and Speedometer share the "INDIC Fuse 10am". It looks like this fuse also ties into the rear defogger timer. Sounds like a good place to start. As far as getting a wiring diagram, Chiltons manuals have some diagrams that if read correctly can be very helpful. They cover a lot of models, so make sure you are on the right diagram, and good luck on your problem.
Jan 1, 2007 at 8:36 AM
Suggested Repair
Check the INDIC 10-amp fuse shared by the oil pressure gauge and speedometer; it also ties into the rear defogger timer. Use a Chilton manual and confirm you are on the correct diagram for this model.
Conversation Summary
The owner of a 1992 Chevrolet Lumina APV said the AC clutch froze and then the speedometer, oil pressure gauge, rear window wiper, and heat stopped working, with suspected wiring damage. They asked where to find a wiring diagram. The expert said the oil pressure gauge and speedometer share the INDIC 10-amp fuse, which also connects to the rear defogger timer, and recommended starting there and using a Chilton manual for diagrams.
