1995 Chevrolet Pickup Park Neutral
1995 CHEVROLET
SANTIAGO.Z
i just got a chevy pickup automatic but when i puy it in park its like if it was in natural do i need to adjust the gears and if i do how can i do it..........................and 1 more question my turn signals dont work i put a new fuse in the fuse box but every time i turn the engine on it blows out thaxz 4 youre help :D
Jan 29, 2007 at 1:07 PM
  • 75,988 POSTS
Try adjusting the linkage at the tranny-your Q-you have a dead short on that circuit-start at the wiring to the turn signal lites-check everyone of them for a hot wire touching ground.
Jan 29, 2007 at 8:30 PM
Suggested Repair
Adjust the shift linkage at the transmission so Park engages correctly. For the turn signals, treat the blown fuse as a short to ground and inspect the turn-signal light wiring for a hot wire touching ground.
Conversation Summary
The owner of a 1995 Chevrolet pickup says the automatic transmission feels like it is in neutral when placed in Park and asks whether the linkage needs adjustment. The turn signals also fail and blow a new fuse whenever the engine is started. The expert recommends adjusting the linkage at the transmission and checking the turn-signal light wiring for a hot wire shorted to ground.
