1987 Chevrolet P30 Not Charging
CHEVROLET
RAF
I have a 1987 class A motorhome on a chevy p30 chassis. It has 103,000 miles with the 454 ci engine.
I have just replaced the starter, the alternator and the battery and the last time I drove it, I lost all 12 volt power and voltage gauge dropped all the way down to nothing. It seems as though the system is not charging. I charged the battery when I got home and it is reading 13.35 volts two days later while not running the engine. When I start the engine the voltage reading is 12.75 volts.
Any ideas ?
Jul 24, 2007 at 8:36 AM
  • 75,988 POSTS
[quote:2f37dd813a="raf"]I have a 1987 class A motorhome on a chevy p30 chassis. It has 103,000 miles with the 454 ci engine.
Any ideas ?[/quote:2f37dd813a]
Did you have it fixed
Aug 5, 2007 at 1:15 AM
RAF
[quote:29bbe24cda="rasmataz"][quote:29bbe24cda="raf"]I have a 1987 class A motorhome on a chevy p30 chassis. It has 103,000 miles with the 454 ci engine.
Any ideas ?[/quote:29bbe24cda]
No, not yet.
Did you have it fixed[/quote:29bbe24cda]
Aug 7, 2007 at 8:51 AM
  • 75,988 POSTS
No, not yet. Did you check the gauges fuse 20amp. Now go behind the alternator turn key to On-Batt and the wire connector with 2 small wire should have battery voltage. Comeback and tell me-meantime I'll be taking
https://images.2carpros.com/forum/automotive_pictures/12900_baby_smoking_11.gif
Did you have it fixed[/quote:cf0ad2ad15][/quote:cf0ad2ad15]
Aug 7, 2007 at 4:37 PM
Suggested Repair
Check the 20-amp gauges fuse. With the key in On/Batt, confirm the two-wire connector behind the alternator has battery voltage, then report the readings.
Conversation Summary
The owner of a 1987 Chevrolet P30 Class A motorhome with a 454 replaced the starter, alternator, and battery, then lost all 12-volt power while driving. Battery voltage was 13.35V at rest and 12.75V with the engine running, suggesting the system was not charging. The expert advised checking the 20-amp gauges fuse and verifying battery voltage at the alternator's two-wire connector with the key on.
