blazer abs and parking brake light?
CHEVROLET
HAWAIISTANG
hi i've had this problem for some time now, my 01 blazer LT 4x4 has had the abs and parking brake light come on randomly when i start my blazer, some times it will and sometimes it wont, when it comes on it doesnt go out until i shut the vehicle off and start it again.....sometimes it goes out that way, sometimes.....others i just have to drive it to where i'm going then when i get out and do what i have to do and get back in and start it it goes out....it seems to never come on after i drive it a while only when i first start it up.......?????!!!!
when it was raining last week i tried slamming on the brakes to see what would happen....and the rear started to slide..the front seemed to work it did it's usual shuffle that abs does but the rear didnt......
i tried using brake cleaner to clean the brake parts in the back thinking that could be the problem but to no avail.....i'm still stuck with this problem.....brought the vehicle to checker auto parts the scanned it but their scanner doesnt pick up abs codes so i'm kinda screwed here i guess.......
sorry this is so long i just wanted to expalin the best i could
thanks everyone for any help
Apr 9, 2006 at 5:28 AM
JACOB62
  • 50 POSTS
my s-10 has the same two lights come on randomly while driving the sometimes they go off on there own and other times they disapear when the vehicle is turned off then back on ... there are no problems with my brakes that i know of they stop fine and the parking brake works fine and is off when the two lights come on always both together never just one or the other... so i am wondering is there some sensor back by the pb to do with the abs cuz im pretty sure my front two sensors are fine cuz i cleaned them with sensor cleaner.. and this happens only here and there ... what can i do to figure this out?
Apr 6, 2012 at 2:28 AM
  • 110,194 POSTS
Have you checked for trouble codes related to the brake system?
Jun 26, 2012 at 2:08 AM
