1996 Chevrolet Lumina Tire Noise
Suggested Repair
Replace the inexpensive tires, which may be flat-spotted from sitting, and inspect the tread and sidewalls for bulges or damage. Also have the alignment and front end checked because the steering wheel sits off-center when driving straight.
Conversation Summary
The owner of a 1996 Chevrolet Lumina with 105,000 miles reported a rhythmic whump noise at any speed. The inexpensive tires had sat unused, and the steering wheel was at about the 3 o'clock position when driving straight, with a slight low-speed click. An expert suggested flat spots from storage, inspection for bulges, new tires for regular driving, and a front-end check if the noise was felt in the steering. The owner found the front wheels tight, did not rotate the tires because the rears were equally worn, and decided to install a new set.
