A/c clutch will not turn on
CHEVROLET
MOUNTAINDAN
  • 6 POSTS
I Have a 2001 S10 quad cab with a 4.3l. The A/C clutch will not ingage. I can manually operate the relay and the clutch operates. Will a bad pressure switch allow it to operate manually or is that after the relay? I have not checked the freon level.
Jul 10, 2006 at 12:16 PM
MIKEYBDMAN
  • 623 POSTS
If your freon is too low, your clutch will never engage to run the compressor. I would have the system evacualted and service back to the proper level of freon first. If then it doesnt run, lets talk switches and wiring......
Jul 13, 2006 at 10:04 AM
