1969 Chevrolet El Camino Shift Problem
1969 CHEVROLET
BIZZYBE12B
well i have a 69 elcamino
in i have a problem i rebulit the whole motor
votec head to big cam new pistonz everything
n i also put the old tranni but i installed a tci shift kit.
well this has been takin a while so im kinda tried. bt i love workin on Cars . i think i just want to drive it .
bt yea it dosent want to go in low gear. and when its in drive it reving pretty high.and when i get under the car in try to shift it it feels like its geting stuck in the low gear.bt it goes into P R N D (kinda) 2 (kinda) :evil: before i take the pan aand everything off i wanted to get ur insight
Aug 1, 2007 at 5:50 PM
  • 75,988 POSTS
[quote:493ab09dfd="bizzybe12b"]well i have a 69 elcamino
bt yea it dosent want to go in low gear. and when its in drive it reving pretty high.and when i get under the car in try to shift it it feels like its geting stuck in the low gear.bt it goes into P R N D (kinda) 2 (kinda) :evil: before i take the pan aand everything off i wanted to get ur insight[/quote:493ab09dfd]
You probably need to adjust the linkage, also check the vaccum hose for leakage and the modulator-What type of tranny-Powerglide, THM 200/350/400
Aug 1, 2007 at 10:40 PM
Suggested Repair
Adjust the transmission shift linkage, check the vacuum hose for leaks, and inspect the modulator. Also identify the transmission type (Powerglide or THM 200/350/400) before dropping the pan.
Conversation Summary
The owner of a 1969 Chevrolet El Camino rebuilt the engine and reinstalled the original transmission with a TCI shift kit. It will not go into low gear, revs high in drive, and feels stuck when shifted from under the car, though the selector reaches park, reverse, neutral, drive, and second somewhat. The expert recommends adjusting the linkage, checking the vacuum hose for leaks and the modulator, and confirming the transmission type.
