2006 Other Chevrolet Models noise coming from front left whe
2006 CHEVROLET
44,000 MILES • 4 CYL • FWD • AUTOMATIC
ALLEN_40403
i have noticed a ttttttt or rotating noise coming from my front left wheel its not a grinding noise but more like a roar or somthing the shock was squeaking before this when it was cold and if i hit a bump this noise is constant when i am driving .it does not change as i turn or anything what could this be ?
Nov 30, 2008 at 8:17 AM
  • 31,937 POSTS
Hi there,
You will have to inspect the front wheel bearing for play, there should be none, check brakes and drive line for any looseness, check for foreign body stuck in drive line or breaks, check drive shafts, check tyres for something embedded in the tread, start here.
Mark (mhpautos)
Nov 30, 2008 at 8:22 AM
ALLEN_40403
since it stared only after the shock squeak could that be the problem ?
Nov 30, 2008 at 8:25 AM
  • 31,937 POSTS
Hi there,
If the noise is when the car is in motion it will be in the drive line, something that is rotating , front bearing, brakes, drive shaft, i would be looking here.
Mark (mhpautos)
Nov 30, 2008 at 8:36 AM
