2001 Other Chevrolet Models Fan only works on High
2001 CHEVROLET
61,000 MILES • 4 CYL • FWD • AUTOMATIC
SCHAEFG
I have a 2001 Chevy Prizm. The fan control for the heater only works on the High setting. I was unable to locate a fuse for the fan, but since it works on High, I don't think it is the fuse. Is the fan motor burned out or is there something else I can check?
Jan 8, 2008 at 12:49 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0eaef36789="schaefg"]Heater problem
2001 Other Chevrolet Models 4 cyl Front Wheel Drive Automatic 61,000 miles
I have a 2001 Chevy Prizm. The fan control for the heater only works on the High setting. I was unable to locate a fuse for the fan, but since it works on High, I don't think it is the fuse. Is the fan motor burned out or is there something else I can check?[/quote:0eaef36789]
Its blower motor resister
Check around the blower motor for a wiring plug it has 4 or 5 wires
replace resister and all should be ok
good luck
let me know
Jan 8, 2008 at 12:57 PM
