2000 Other Chevrolet Models Starting problems
2000 CHEVROLET
116,000 MILES • 4 CYL • FWD • AUTOMATIC
KINGSMENRJ
My 2000 chevy prizm will not start. I poured fuel into the throttle body and it starts but dies. The fuel pump is pumping once I remove the line. Could it be the voltage going to the injector? I removed the injectors and tested them and they make contact noises and sprays, but it will only start after the fuel leaks into the injectors after a couple of miniutes.
Not sure what to do.
Thanks
Jun 12, 2008 at 5:56 AM
RHALL77
  • 3,361 POSTS
check fuel pressure. let me no what you find
Jun 12, 2008 at 6:05 AM
