2000 Other Chevrolet Models Oil for manual transfer case
2000 CHEVROLET
103,000 MILES • V8 • 4WD • MANUAL
GARYARD
  • 8 POSTS
In a 2000 chevy 2500 pickup duramax 6.5 with a manual Tranny and Manual transfer case can gl5 be used in the transfer case instead of ATF.
Thanks
Gary
Nov 22, 2009 at 2:29 PM
  • 31,937 POSTS
Hi there,
If the manufactures specify a spec oil type and grade it is for a good reason, other oils will not satisfy the lubrication needs such as viscosity, load bearing, heat transfer capacity, coefficient of friction requirements, changing the oil specs are fraught with danger, i would not do this at all, What is your thinking behind this change?
Mark (mhpautos)
Nov 22, 2009 at 7:44 PM
GARYARD
  • 8 POSTS
I had the truck serviced at a local garage, when I got the bill I noticed they put GL5 in the transfer case when I questioned them I was shown a " repair manual " they use that specified GL5 for this application. I didn't agree, but they said that was the new spec.
Nov 22, 2009 at 10:22 PM
  • 31,937 POSTS
Hi there, all i can find is the original specs, i see no suppression for this, best you contact a dealer for the latest information, but i feel it should be running the ATF if that is the original spec... let me know what you find out and i can make an amendment in our data base.
Mark (mhpautos)
Nov 23, 2009 at 7:21 AM
