2000 Other Chevrolet Models how to change radiator drain plu
2000 CHEVROLET
KJIZZLE30
Engine Cooling problem
2000 Other Chevrolet Models 6 cyl Two Wheel Drive Automatic
water leaking out the bottom of radiator drain hole on a 2000 olds alero v6 3.4 engine was wondering how to change plug
Aug 20, 2009 at 8:36 AM
HMAC300
  • 48,601 POSTS
if the plug is replaceable, you'll have to look to see if it has a screw type or just a half screw. they are plastic and kind of fragile. Mke sure it is the plug and not the raiator itself leaking from the hole where the plug is.
Nov 30, 2009 at 12:41 PM
