2000 Other Chevrolet Models 1.6 Tracker 2door power loss
2000 CHEVROLET
1 NOTWALKING
Engine Performance problem
2000 Other Chevrolet Models Two Wheel Drive Manual 80.000 miles
45MPH going up small hills
2000 Chevrolet Tracker 1.6 stick shift* replaced fuel filter/air filter/gas cap. Removed EGR/ no carbon/all coils ohm 23/ terminals #2 & #5 12.37vdc to ground. I pulled codes 420,400,440 and 455. I know there are emission control issues but can not solve the loss of power problem.
Checking the EVAP system The EVAP canister vent valve is not receiving voltage @ to open when at warm engine temp. Could some one aid me in what to check repair.
What prompt me to start trouble shooting/ I loose power driving up hills.
Oct 6, 2008 at 5:55 AM
MERLIN2021
  • 17,250 POSTS
Check fuel pressure and for clogged catalytic converter, You can do a backpressure test by removing the 02 sensor before the cat, install the pressure gauge, and if it's more than 1 1/2 to 2 psi the cat is clogged. What does it do on flat ground under hard acceleration? P0420 is the catalyst efficiency code, could mean a bad cat! Too much backpressure can cause some of the other codes.
Oct 7, 2008 at 10:07 AM
1 NOTWALKING
I removed the top H2O and installed a port to test pressure was .600 pisig or 17 in W.C.
The car seems to run OK for a few miles and then decelerates up hills and very slow response on a flat surface.On a flat road it will slowly increase speed to 65 MPH.
thank you for your response.
Oct 7, 2008 at 12:35 PM
