1999 Other Chevrolet Models Air Cond. fan shut off
1999 CHEVROLET
99,000 MILES • V8 • 2WD • AUTOMATIC
SHOOTER1
Driving and the Air Cond. fan quit then came back on for about 5 sec. Then went off again. will not come back on...Checked fuse under dash and also under hood..the Air Cond clutch will try to engage, but only for a few sec.Just filled it with freon about 1 wk ago. Could it be a relay ? I checked all the fuses ,even ones that were marked for other items.. all good...Help its hot in Texas...thanks
Jul 4, 2010 at 8:14 AM
HMAC300
  • 48,601 POSTS
depending on how big a leak the a/c system has is why it won't blow cool. it should be fixed as you may have wasted your money by putting in the freion. run a hot wire to the blower and see if it runs if it does, then it can be the relay/switch/ or resistor causing the problem. it should be checked out by a pro....
Jul 10, 2010 at 11:38 AM
