1998 Other Chevrolet Models Can'y Start
1998 CHEVROLET
160,000 MILES • V8 • 2WD • AUTOMATIC
JAMIE11111
I have a 1998 Chevy 350 Vortec P30 that was a school bus that we have turned into a rv. I was driving and had my foot on the brake petal. I must have kicked a wire that grounded out.There was some smoke and then everything went dead. When you turn the key nothing happens. Some of the lights work. Only about a 1/4 of the fuse box has power. We found the wire, it is red 12agw. We then pluged in it back into a distribution block that appears to send power to 4 other wires that go to different parts of the fuse block. But after doing this there is still no power. The red wire should have 12V+ I think but I can't find a source for it's power. All the fuses I have checked are good. What could have happen? A relay, a fuse I'm not seeing?
Mar 15, 2010 at 11:05 AM
  • 75,988 POSTS
Hi Jamie11111, Welcome to 2carpros and TY for the donation You need to test all your fusible links if all okay -test the ignition switch for power in to it and out of it-
https://images.2carpros.com/forum/automotive_pictures/12900_f1_15.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f2_15.jpg
Mar 15, 2010 at 4:36 PM
JAMIE11111
The guy looking at my bus checked the fusible links and says they are ok. He doesn't want to remove the ignition switch but I think he is going to now because you are the third one to tell him to check it.
Mar 15, 2010 at 4:47 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 19, 2010 at 9:58 AM
