1998 Chevy Metro Dies While Driving
1998 CHEVROLET
THE SCROUNGE
My Metro has 145000 Mi. In the past 2 months I have been experiencing temporary loss of power driving on the hwy or streets. Sometimes it just dies
and then I can restart it and sometimes I can't. We
have already replaced the fuel pump, coil, Ignition module, Temperature sensor and it still has not taking care of this problem. This morning I went to start it and it starts fine. Runs like a champ when idling or maybe for a week or two. Could it be a computer problem.
Thanks, Frank
Jul 25, 2007 at 5:38 AM
2CARPRO JACK
  • 11,533 POSTS
When it dies, does it feel like it is running out of fuel or just signs off? Did you also replace the fuel pump relay?
Jul 25, 2007 at 8:14 AM
THE SCROUNGE
It acts like its running out of fuel, kind of surges up then down. When I made it of the off ramp then it died. At first it would crank and not start but I waited a few minutes then it started. I proceeded homeward and it did this 3 times and finally would not restart yesterday but this morning it started up just fine. To my knowledge I don't believe we replaced the fuel pump relay switch.
Jul 25, 2007 at 8:25 AM
2CARPRO JACK
  • 11,533 POSTS
I would probably start ther, it is inexpensive and when the pumps get old they tend to draw more amps, which takes a toll on the relay
Jul 25, 2007 at 10:55 AM
Suggested Repair
Replace the fuel pump relay. It is inexpensive, and an aging fuel pump can draw more current and overload the relay, causing fuel-starvation symptoms.
Conversation Summary
A 1998 Chevy Metro with 145,000 miles intermittently loses power and dies, then may not restart until later. The fuel pump, coil, ignition module, and temperature sensor were already replaced. The owner said it surges as if running out of fuel and the fuel pump relay was not replaced. The expert recommended starting with the inexpensive fuel pump relay because older pumps can draw more current and stress the relay.
