1997 Other Chevrolet Models Blower motor/ Fan speed
1997 CHEVROLET
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDSTROKE2
I have a '97 chevy S10 Jimmy with a blower motor problem. The blower motor started cutting out from time to time and now won't run at all. I disconnected the plug from the blower motor and applied 12 volts to it and it ran fine. Checked the switch and it has power to it when the a/c is on. The compressor is kicking on as well when the switch is turned on. My next thing was to check the fan speed relays but can't find them. Also I read that there's a fan speed resistor somewhere but can't find it either. Any help would be appreciated!!
Thanks
Jun 17, 2009 at 12:57 PM
Check the blower motor relay and the blower motor resistor
Blower relay is on center rear of engine compartment and resistor is on right rear of engine compartment on blower module
Jun 17, 2009 at 2:19 PM
