1997 Other Chevrolet Models ALDL Plug
1997 CHEVROLET
17,000 MILES • V8 • 2WD • AUTOMATIC
FLARESIDE
I currently have an ABS light that is on, I went to have the code read and found out there is no power at the plug. Is there a way to find out the schematic for the wiring on the plug? I tried to follow the wires but it is imposable to trace it to the source. I would like to re wire a 12 volt lead to the proper pin.
Being a conversion it appears the wires might have been cut during the make over. The chassis is a P30 Chevy with a 454 ci motor.. Thanks for the help.
Nov 9, 2008 at 1:12 AM
DAVE H
  • 13,384 POSTS
if i have got the right vehicle diagram .. 1997 P30 cutaway commercial chassis then ther is 4 wires ???
going to the DLC on the left interior bulkhead near relay bracket ??
wires
1) purple - is serial data wire from VCM (vehicle control module)
4) black - to earth/ground at left interior bulkhead near relay plate
5) black - to earth/ground on rear of cylinder block
16) orange - to engine/battery fuse at I/P fuse box 15 amp
Nov 13, 2008 at 6:39 PM
